Problem with Variable within an Expression
I am trying to use an if() expression with a variable like so -
{{ $if($(‘Loop Over Items2’).item.json.row_number = 3, “Here is an image URL for this section, please integrate it within the section text with left alignment and wrap around text - $(‘HTTP Request8’).item.json.guid.rendered”, “”) }}
This should print the variable (a URL) IF the row number = 3…right?
Except this is what it returns -
It is merely printing the variable text, not the actual value. What am I doing wrong?
  • n8n version: 1.63.4
  • Operating system: windows 11pro
Hey @Anthony_Lee , you are assigning the number 3, not comparing. To compare, use == instead.
Ah. Thank you
