Hi everyone !
I’m experiencing a weird problem with webhooks. I have totally understand the difference between prod and test links but none of them works → for the test for example, when i execute the node, and go to the link which tell me {“message”:“Workflow got started.”}, nothing prompt in the results window and it continue to “load” in loop (see screenshot). For being sure that there is no problem in my n8n configuration, i tried the video of Sven where he do exactly the same (take the test link, start the node, and see results with no problems). Can you help me on this ?
thank you all !
Configuration :
Docker container
Last version of n8n
Tunnel mode with my ‘n8n.domain.com’
