Hi N8Ners, can anyine give me any pointers on why this node is executing correctly? The node is pulling data ‘content’ from a Deepseek node and should put it into a description in Wordpress but its not pulling the data through the node. Obviously a problem with the description code but I cant work out what it is
Hey @Brian_King hope all is well. Welcome to the community.
Try
{{ $node["Deepseek - tasting note"].json.message.content }}
or
{{ $('Deepseek - tasting note').item.json.message.content }}
or (if the deepseek - tasting note happens to be just before your Create a product node
{{ $json.message.content }}
First one worked. You’re a legend thanks! (i’ve been using Kimi Ai for help me with this and so far it couldnt solve the problem!)
Yay! Glad I could help.
Kindly mark my answer as Solution. Thank you.
Cheers!
