Problem with WriteBinary Workflow onWorkflowPostExecute
Hi, ihave this issue:
There was a problem running internal hook “onWorkflowPostExecute” Error: InternalHooks not initialized
at Function.getInstance (/home/stefan/.nvm/versions/node/v17.0.1/lib/node_modules/n8n/dist/src/InternalHooksManager.js:11:15)
at /home/stefan/.nvm/versions/node/v17.0.1/lib/node_modules/n8n/dist/src/WorkflowRunner.js:60:62
at runMicrotasks ()
What is wrong ?
Thanks,
Stefan
Can you please tell me when exactly that happens. How do you for example start the workflow? Via the CLI?
Yes, the thing is i have a lot of files to write to hdd. But the workflow stops after 1499 Files. And the n8n hang. Then i think i have to start it via cli to get these messages.
I made you a screencast.
You have PM. Thanks,
Stefan
Thanks a lot for confirming.
Had a look and found and fixed the issue. Will be released with the next version. For now you would sadly have to use temporarily [email protected].
Jan, thanks. Great work.
Got released with [email protected]
