Problem ... workflow could not be activated
Hi there,
I copied a workflow from n8n.cloud to the n8n App on my MacBook Pro (M1). It runs fine, but when I try to activate it, I get the following error:
Change the path in the Webhook-Node. It should then work fine.
Thanks Jan, that did the trick!
Glad to hear. Have fun!
