Issue during step 2 of the Hands-On exercise, N8N101
Hello everyone,
When I try to complete step 2 of the hands-on exercise for the N8N101 course (Transform the data), I get an error at the final validation step when making the HTTP POST request to https://learn.app.n8n.cloud/webhook/course/n8n101/process-orders.
Here’s the error returned:
"errorMessage": "Your request is invalid or could not be processed by the service",
"errorDescription": "Your order totals are incorrect. Please ensure you are calculating the totals correctly.",
"errorDetails": {
"rawErrorMessage": [
"422 - \"{\\\"error\\\":\\\"Your order totals are incorrect. Please ensure you are calculating the totals correctly.\\\"}\""
"httpCode": "422"
"n8nDetails": {
"nodeName": "HTTP Request",
"nodeType": "n8n-nodes-base.httpRequest",
"nodeVersion": 4.4,
"itemIndex": 0,
"time": "19/06/2026 22:00:38",
"n8nVersion": "2.26.8 (Self Hosted)",
"binaryDataMode": "filesystem",
"stackTrace": [
"NodeApiError: Your request is invalid or could not be processed by the service",
"    at ExecuteContext.execute (/usr/local/lib/node_modules/n8n/node_modules/.pnpm/n8n-nodes-base@file+packages+nodes-base\_@aws-sdk+credential-providers@3.808.0_asn1.js@5_8da18263ca0574b0db58d4fefd8173ce/node_modules/n8n-nodes-base/nodes/HttpRequest/V3/HttpRequestV3.node.ts:865:16)",
"    at processTicksAndRejections (node:internal/process/task_queues:104:5)",
"    at WorkflowExecute.executeNode (/usr/local/lib/node_modules/n8n/node_modules/.pnpm/n8n-core@file+packages+core\_@opentelemetry+api@1.9.0\_@opentelemetry+exporter-trace-otlp_cf5896492347c4895f0373f4acc773d7/node_modules/n8n-core/src/execution-engine/workflow-execute.ts:1053:8)",
"    at WorkflowExecute.runNode (/usr/local/lib/node_modules/n8n/node_modules/.pnpm/n8n-core@file+packages+core\_@opentelemetry+api@1.9.0\_@opentelemetry+exporter-trace-otlp_cf5896492347c4895f0373f4acc773d7/node_modules/n8n-core/src/execution-engine/workflow-execute.ts:1327:11)",
"    at /usr/local/lib/node_modules/n8n/node_modules/.pnpm/n8n-core@file+packages+core\_@opentelemetry+api@1.9.0\_@opentelemetry+exporter-trace-otlp_cf5896492347c4895f0373f4acc773d7/node_modules/n8n-core/src/execution-engine/workflow-execute.ts:1778:27",
"    at /usr/local/lib/node_modules/n8n/node_modules/.pnpm/n8n-core@file+packages+core\_@opentelemetry+api@1.9.0\_@opentelemetry+exporter-trace-otlp_cf5896492347c4895f0373f4acc773d7/node_modules/n8n-core/src/execution-engine/workflow-execute.ts:2474:11"
I’ve followed the entire workflow as described in the instructions, but I keep getting the same response from the HTTP request.
Has anyone been able to validate this step?
Here’s my workflow:
Thank you for your help!
Hello,
This is a hardone to see. You have a space in your ’ order_total’ variable so it’s failing. Remove the space at the beginning and you’re good to go.
cheers,
Wow thank you so much, it works!
I’m curious to know how you found that error?
Our backend was throwing the invalid variable name, and when I expected the payload being sent, i noticed there was a space in the name. It took me a good 10 minutes to notice it as well.
