Problems in creating credential in CloudConvert node
Hello everyone,
Im currently facing a problem of connecting my credential via API key and OAuth2 in CloudConvert node. Im following the instructions inside this GitHub - cloudconvert/n8n-nodes-cloudconvert and here is what i get:
  • OAuth2: im pasting the OAuth Redirect URL into the website but it say: Something went wrong. Please try again.
    -API Key: im pasting correctly the API Key generated into my credential set up but after trying to connect, it say : Couldn’t connect with these settings
    The resource you are requesting could not be found.
    NOTE: Im running n8n locally via Docker. my n8n version is 1.112.5
    Thank you for reading my problem !
  • n8n version: 1.112.5
  • Operating system: Windows
You can t use “localhost” , you need a publicly URL (ngrok or alteernatives).
After you set the WEBHOOK_URL in youe envirnment, you can copy and pste the new url in the CloudConvert.
thank you so much
