Hi! I’m super new to deploying apps on my own VPS, but loving N8N so far!
I am however facing an issue trying to update the version, currently on 0.184.0 and I deployed to heroku using this one-click button here GitHub - sarveshpro/n8n-heroku: n8n docker implementation for heroku.. I followed the npm update instructions (see below) and getting the below response, with N8N still showing 9 updates available.
Appreciate this is a rather noob question, but keen to get updated to the latest version on my own VPS (rather than the cloud/SaaS version).
Response from update command as below:
npm WARN deprecated [email protected]: request-promise-native has been deprecated because it extends the now deprecated request package, see https://github.com/request/request/issues/3142
npm WARN deprecated [email protected]: Please upgrade to version 7 or higher. Older versions may use Math.random() in certain circumstances, which is known to be problematic. See https://v8.dev/blog/math-random for details.
npm WARN deprecated [email protected]: The querystring API is considered Legacy. new code should use the URLSearchParams API instead.
npm WARN deprecated [email protected]: request has been deprecated, see https://github.com/request/request/issues/3142
npm WARN deprecated [email protected]: this library is no longer supported
npm WARN deprecated [email protected]: Please upgrade to latest, [email protected] or [email protected]! Check these notes: https://bit.ly/2ZEqIau
npm WARN deprecated [email protected]: core-js@<3.23.3 is no longer maintained and not recommended for usage due to the number of issues. Because of the V8 engine whims, feature detection in old core-js versions could cause a slowdown up to 100x even if nothing is polyfilled. Some versions have web compatibility issues. Please, upgrade your dependencies to the actual version of core-js.
added 7 packages, removed 40 packages, changed 501 packages, and audited 1351 packages in 4m
110 packages are looking for funding
run `npm fund` for details
8 vulnerabilities (1 moderate, 7 high)
To address all issues (including breaking changes), run:
npm audit fix --force
Run `npm audit` for details.
npm notice
npm notice New minor version of npm available! 8.15.0 -> 8.19.1
npm notice Changelog: https://github.com/npm/cli/releases/tag/v8.19.1
npm notice Run npm install -g [email protected] to update!
npm notice
There isn’t any more to the output no (just process exited from Heroku console) - it seems an install process was carried out, but even after restarting my dyno and navigating back to the live link, N8N still showing as not updated (still 9 updates behind latest)
I don’t think we had an official one 2 years ago, But to update it you will need to update your Heroku git project from wherever you installed it from.
Our official one is here: GitHub - n8n-io/n8n-heroku but it would have the same problem where it would need a commit to update.
If you can access the Heroku git repository your settings were showing you could change the version there and push a change which should trigger an update as well.
That I don’t know, I am not that familiar with Heroku. In your screenshot I noticed the Heroku git URL of https://git.heroku.com/beats-n8n.git is that not something you have access to?
Have you worked out where you installed n8n from yet as well, As it was 2 years ago it probably wouldn’t be ours so knowing that would also be a massive help.
