Hello everyone,
I’m new with n8n, I hope you can help me.
After receiving a message from a lead, what I want to do with Basic LLM chain, rocama and JSON Parser:
Qualify the lead.
Create a short text that indicates the lead’s intention.
This is the workflow.
I don’t know if this can be done in the same step and I don’t know if it is necessary to use JSON Parser.
What I’m looking for is to obtain a JSON with the attributes qualified (point 1) and summary (point 2) and be able to continue with the workflow.
If more information is needed I will add what is necessary, I need to unblock this problem as soon as possible.
I am looking forward to your response.
Greetings and thank you.
n8n
June 3, 2024, 3:12pm
2
n8n version:
Database (default: SQLite):
Operating system:
Jon
June 5, 2024, 4:16pm
3
Hey @Marcos_rodriguez_mor ,
Welcome to the community
Can you share an example output from the code node so we can take a look? Have you also looked at our AI workflow templates to see if anyone has done anything similar before with the JSON parser?
system
Closed
September 3, 2024, 4:16pm
4
