Process a PDF using an LLM
I want to process a PDF using an LLM.
For example, creating a prompt saying that I am going to upload a PDF (binary or base64) and I want to extract all the information (graph, tables, etc.) and then process the information.
The PDF to Text component doesn’t help because I don’t want to remove just the text, I want an LLM to interpret graphics, tables, etc.
The knowledge base doesn’t help in this case because I want to do some processing on the file before putting it somewhere.
The output can be a structured json or a simple text containing all the content “interpreted” by an LLM
  • n8n version: 1.78.0
  • Database (default: SQLite): SqlLite
  • Operating system: linux
You can turn the PDF into images before processing it with an AI.
Here are two workflows from @jimleuk that shows exactly how to achieve that:
In the first one he loads the image directly.
In the second one he uses a third-party API to turn the PDF pages into images and then loads the binary file into the AI node
:muscle: If my reply answers your question, please remember to mark it as a solution.
I had found another solution, including following the worflow below:
However, your solution allows for greater flexibility. Thanks
