Production URLs using localhost
I’m having an issue with the resumeURL resolving as localhost instead of my actual domain, but only for production runs. Most instances of this issue I’ve found point to not having WEBHOOK_URL set, but it is here.
-I do not see localhost in the UI anywhere.
-Triggering anything from within the browser / manually works 100%.
-Triggering webhook with test URL and then sending {{ $execution.resumeUrl }} via email = correct domain
-Triggering webhook with prod URL and then sending {{ $execution.resumeUrl }} via email = localhost
Not sure what’s missing here.
Full compose
version: "3.8"
services:
  n8n:
    image: docker.n8n.io/n8nio/n8n:latest
    restart: unless-stopped
    environment:
      # Public URLs (important behind proxy/tunnel)
      N8N_HOST: ${SUBDOMAIN}.${DOMAIN}
      N8N_PROTOCOL: https
      N8N_PORT: 5678
      WEBHOOK_URL: https://${WHSUBDOMAIN}.${DOMAIN}/
      #N8N_EDITOR_BASE_URL: https://${WHSUBDOMAIN}.${DOMAIN}/
      #N8N_DISABLE_PRODUCTION_MAIN_PROCESS: true
      # Required shared secret
      N8N_ENCRYPTION_KEY: ${N8N_ENCRYPTION_KEY}
      # Timezone (use IANA TZ format)
      GENERIC_TIMEZONE: America/New_York
      TZ: America/New_York
      # Queue mode
      EXECUTIONS_MODE: queue
      QUEUE_BULL_REDIS_HOST: redis
      QUEUE_BULL_REDIS_PORT: 6379
      # Postgres (doc-backed variables)
      DB_TYPE: postgresdb
      DB_POSTGRESDB_HOST: postgres
      DB_POSTGRESDB_PORT: 5432
      DB_POSTGRESDB_DATABASE: ${DB_NAME}
      DB_POSTGRESDB_USER: ${DB_USER}
      DB_POSTGRESDB_PASSWORD: ${DB_PASSWORD}
    ports:
      - "5678:5678"
    volumes:
      - n8n_data:/home/node/.n8n
    depends_on:
      - postgres
      - redis
    networks:
      - n8n_net
  n8n-worker:
    command: worker
    environment:
      # Must match main for credentials decryption
      #values for worker for reference if needed
      #WEBHOOK_URL: https://${WHSUBDOMAIN}.${DOMAIN}/
      #N8N_HOST: ${SUBDOMAIN}.${DOMAIN}
      #N8N_PROTOCOL: https
      # Queue mode (workers connect to same Redis)
      # Postgres
      DB_TYPE: postgresdb
    depends_on:
      - postgres
      - redis
    volumes:
    networks:
      - n8n_net
  postgres:
    image: postgres:15
    environment:
      POSTGRES_USER: ${DB_USER}
      POSTGRES_PASSWORD: ${DB_PASSWORD}
      POSTGRES_DB: ${DB_NAME}
    volumes:
      - postgres_data:/var/lib/postgresql/data
    networks:
      - n8n_net
  redis:
    image: redis:7-alpine
    command: ["redis-server", "--appendonly", "yes"]
    volumes:
      - redis_data:/data
    networks:
      - n8n_net
  cloudflared:
    image: cloudflare/cloudflared:latest
    command: tunnel --no-autoupdate run --token ${CF_TUNNEL_TOKEN}
    depends_on:
      - n8n
    networks:
      - n8n_net
networks:
  n8n_net:
volumes:
  n8n_data:
  postgres_data:
  redis_data:
  • n8n version: 2.22.5
  • Database (default: SQLite): postgresdb
  • Operating system: ubuntu
Hi @flowdan
The problem is that your n8n setup is split into two parts: a main controller and a “worker” that handles the actual work for production runs. While you told the main controller what your website address was, the worker was left in the dark because those settings were commented out in your configuration. When the worker tried to create the resume link, it didn’t know your domain name, so it defaulted to “localhost.”
To fix this, you simply need to give the worker the same address information as the main controller. By uncommenting the WEBHOOK_URL, N8N_HOST, and N8N_PROTOCOL lines in the worker section of your Docker file and restarting the service, the worker will now know exactly which domain to use when generating those links.
Here is your corrected compose file
version: "3.8"
services:
  n8n:
    environment:
      N8N_PROTOCOL: https
      N8N_PORT: 5678
      # Queue mode
      DB_TYPE: postgresdb
    ports:
      - "5678:5678"
    volumes:
    depends_on:
      - postgres
      - redis
    networks:
      - n8n_net
  n8n-worker:
    command: worker
    environment:
      # FIXED: These must be active for the worker to generate correct resumeUrls
      N8N_PROTOCOL: https
      # Postgres
      DB_TYPE: postgresdb
    depends_on:
      - postgres
      - redis
    volumes:
    networks:
      - n8n_net
  postgres:
    image: postgres:15
    environment:
    volumes:
    networks:
      - n8n_net
  redis:
    volumes:
      - redis_data:/data
    networks:
      - n8n_net
  cloudflared:
    depends_on:
      - n8n
    networks:
      - n8n_net
networks:
  n8n_net:
volumes:
  n8n_data:
  postgres_data:
  redis_data:
Thanks. Initial test appears to have worked, so I think that did the trick.
