Hi! This is a great piece of software…thank you.
I’m trying to get the webhook working and am running into the issue when running curl:
curl -X POST https://n8n.havehopeyo.com/webhook/t
but not when running curl -X POST https://n8n.havehopeyo.com/webhook-test/t
{“code”:404,“message”:“The requested webhook “POST t” is not registered.”}
Here’s my webhook code…super simple…works as expected with the test webhook but not the production. The webhook is saved and activated…have read through the posts here but nothing is working…thank you in advance!! Joel.
"nodes": [
"parameters": {
"httpMethod": "POST",
"path": "=t",
"responseMode": "lastNode",
"responseData": "allEntries",
"options": {}
"name": "Webhook",
"type": "n8n-nodes-base.webhook",
"typeVersion": 1,
"position": [
810,
350
"webhookId": "6a73cc93-b4aa-4ab4-ac8b-1a78d6ba3141"
"connections": {}
