My template was approved yesterday and is available with this link: https://n8n.io/workflows/11948-automatically-submit-sitemap-urls-from-oncrawl-to-google-indexing-api-and-indexnow/
I used to publish another workflow that I deleted
My issue is as follow:
The approved workflow is not available on your template library → https://n8n.io/workflows/11948-automatically-submit-sitemap-urls-from-oncrawl-to-google-indexing-api-and-indexnow/
When searching for: "Submit Sitemaps urls " with your search engine, only the old workflow I deleted is visible and leads to a 404 error → Submit sitemap URLs from Oncrawl to Google Indexing API and IndexNow | n8n workflow template
Could you please: Delete the old workflow so that it won’t appear anymore in the template library → /workflows/11948-submit-sitemap-urls-from-oncrawl-to-google-indexing-api-and-indexnow/
And index the new workflow on the catalog : https://n8n.io/workflows/11948-automatically-submit-sitemap-urls-from-oncrawl-to-google-indexing-api-and-indexnow/Thank
- n8n version: 1.123.5
- Database (default: SQLite):
- Running n8n via (Docker, npm, n8n cloud, desktop app): n8n cloud
- Operating system:
