Pulling P&L (Profit and Loss) Reports from QBO
Hello - I have a workflow where it pulls QBO report data into an excel macro. QBO nodes have all report types except for P&L. From what I understand, for P&L you have to use a HTTP Request node for a custom API. This HTTP node is much tougher to set up.
Has anyone successfully gotten QBO P&L reports to pull via n8n? I could really use some advice, thank you.
Yes it’s possible to pull QBO P&L reports through n8n using the HTTP request node but it actually requires some additional setup compared to other standard reports
Seems like a standard http request for quickbooks, what issue are you having specifically?
The issue was the output in the Process QBO Data node. I had to make some edits to the javascript and also some updates to vba in excel but i finally got it to work. PL summary tab in excel separate from Transaction List tab.
Yea I was just plugging one in and looking at the output and was thinking about how in the world to parse that out. Glad you got it going.
