Python code error in VS Code
Why is an error occurring during execution?
number = 5
if number > 0:
    print("positive")
elif number < 0:
    print("negative")
else:
    print("zero")
If you’re executing this code in a python code node within n8n, you need to make sure that your code does return one or multiple item/s.
# Add a new field called 'my_new_field' to the JSON of the item
_item["json"]["my_new_field"] = 1
return _item
