Python Code with Errors
Why does this code throw an error?
def divide_numbers(a, b):
    return a / b
result = divide_numbers(10, 0)
print("The result is: " + result)
n8n_case02
Hello xcnqa0005, welcome to the n8n Community!
I think youre getting two errors here:
  1. divide_numbers(10,0) causes a zerodivisionerror (you cant divide by zero)
  2. print(“The result is: “ + result“) will also fail because result is a number and you’re tring to concatenate it with a string.
You can try this code:
    if b == 0:
        return "Cannot divide by zero"
    return a / b
print("The result is:", result)
or if your want to always return a number, you can raise a custom error or handle b == 0 differently.
Hope this will works for you! :blush:
