Python eval() not functioning as normal non-Pyodide Python
I am currently building a data transformation node using the Python code node. I understand that it is using Pyodide in the background, but for my use case it has been functioning identically to regular Python. I am currently trying to build some logic that evaluates a string as a literal Python statement. I have tested this outside of n8n and in a Python IDE and works as expected.
def key_to_value(data, data_name):
    for item in data:
        key = data[item]['key']
        value_type = data[item]['type']
        value_in_string = str(data_name + key)
        value = eval(value_in_string)
ERROR: NameError: name ‘json_webhook’ is not defined
Note: json_webhook is the output from the webhook node
  • n8n version: 1.25.1
  • Database (default: SQLite)
  • Running n8n via n8n cloud
Hey @ryan.greene,
Can you share the full code you are using? The error would suggest you are using a variable that is not defined so it would be handy to see where you are pulling that from in your code.
