Below python code started failing after upgrade to 1.123.4 from 1.122 (I believe).
import re
import zlib
import base64
import json
output = []
# Get the binary data from the first input item and decode from base64
#pdf_b64 = items[0]["binary"]["data"]["data"]
pdf_b64 = items[0]["json"]["data"]
#print(pdf_b64)
pdf = base64.b64decode(pdf_b64)
#print(pdf)
stream = re.compile(rb'/EmbeddedFile.*?FlateDecode.*?stream(.*?)endstream', re.S)
for s in stream.findall(pdf):
s = s.strip(b'\r\n')
try:
decompressed = zlib.decompress(s)
decoded = decompressed.decode('utf8')
if 'Invoice' in decoded:
output.append({"json": {"isdoc": decoded}})
except:
pass
return output
Security violations detected
Line 1: Import of standard library module ‘re’ is disallowed. Allowed stdlib modules: none Line 2: Import of standard library module ‘zlib’ is disallowed. Allowed stdlib modules: none Line 3: Import of standard library module ‘base64’ is disallowed. Allowed stdlib modules: none Line 4: Import of standard library module ‘json’ is disallowed. Allowed stdlib modules: none
Error: Security violations detected at throwExecutionError (/usr/local/lib/node_modules/n8n/node_modules/.pnpm/n8n-nodes-base@file+packages+nodes-base_@aws-sdk+credential-providers@3.808.0_asn1.js@5_8da18263ca0574b0db58d4fefd8173ce/node_modules/n8n-nodes-base/nodes/Code/throw-execution-error.ts:11:9) at PythonTaskRunnerSandbox.runUsingIncomingItems (/usr/local/lib/node_modules/n8n/node_modules/.pnpm/n8n-nodes-base@file+packages+nodes-base_@aws-sdk+credential-providers@3.808.0_asn1.js@5_8da18263ca0574b0db58d4fefd8173ce/node_modules/n8n-nodes-base/nodes/Code/PythonTaskRunnerSandbox.ts:56:30) at processTicksAndRejections (node:internal/process/task_queues:105:5) at ExecuteContext.execute (/usr/local/lib/node_modules/n8n/node_modules/.pnpm/n8n-nodes-base@file+packages+nodes-base_@aws-sdk+credential-providers@3.808.0_asn1.js@5_8da18263ca0574b0db58d4fefd8173ce/node_modules/n8n-nodes-base/nodes/Code/Code.node.ts:171:12) at WorkflowExecute.executeNode (/usr/local/lib/node_modules/n8n/node_modules/.pnpm/n8n-core@file+packages+core_@opentelemetry+api@1.9.0_@opentelemetry+sdk-trace-base@1.30_ec37920eb95917b28efaa783206b20f3/node_modules/n8n-core/src/execution-engine/workflow-execute.ts:1045:8) at WorkflowExecute.runNode (/usr/local/lib/node_modules/n8n/node_modules/.pnpm/n8n-core@file+packages+core_@opentelemetry+api@1.9.0_@opentelemetry+sdk-trace-base@1.30_ec37920eb95917b28efaa783206b20f3/node_modules/n8n-core/src/execution-engine/workflow-execute.ts:1226:11) at /usr/local/lib/node_modules/n8n/node_modules/.pnpm/n8n-core@file+packages+core_@opentelemetry+api@1.9.0_@opentelemetry+sdk-trace-base@1.30_ec37920eb95917b28efaa783206b20f3/node_modules/n8n-core/src/execution-engine/workflow-execute.ts:1662:27 at /usr/local/lib/node_modules/n8n/node_modules/.pnpm/n8n-core@file+packages+core_@opentelemetry+api@1.9.0_@opentelemetry+sdk-trace-base@1.30_ec37920eb95917b28efaa783206b20f3/node_modules/n8n-core/src/execution-engine/workflow-execute.ts:2274:11
- n8n version: 1.123.4 (Cloud)
