Refer to the attached screenshots.
If I enter text into these prompt fields (A, B & C in the screenshots) in n8n, will I be charged for input tokens by OpenAI?
the answer is yes
you can find how to calculate token in this link
Thank you for your reply
Do you think it is possible if we track the input and output tokens for each OpenAI node in n8n workflow?
