Hi!
I am trying to publish a message to a RabbitMQ that is running in docker in a different server than n8n’s. I get the following error message when I execute the workflow:
Problem executing workflow
There was a problem executing the workflow:
“Frame size exceeds frame max”
My RabbitMQ is running in docker behind an nginx reverse proxy. The reverse proxy configuration in nginx is set to redirect any incoming request from mydomain.com to port 5672, the port wich my docker container is exposed:
server {
server_name rmq.mydomain.com;
location / {proxy_pass http://127.0.0.1:5672;
proxy_set_header Connection ‘’;
proxy_http_version 1.1;
chunked_transfer_encoding off;
proxy_buffering off;
proxy_cache off;
}listen 443 ssl; # managed by Certbot ssl_certificate /etc/letsencrypt/live/rmq.mydomain.comfullchain.pem; # managed by Certbot ssl_certificate_key /etc/letsencrypt/live/rmq.mydomain.com/privkey.pem; # managed by Certbot include /etc/letsencrypt/options-ssl-nginx.conf; # managed by Certbot ssl_dhparam /etc/letsencrypt/ssl-dhparams.pem; # managed by Certbot
server {
if ($host = rmq.mydomain.com) {
return 301 https://$host$request_uri;
} # managed by Certbotserver_name rmq.mydomain.com;
listen 80;
return 404; # managed by Certbot}
Tests I did so far:
1- In my rabbit credentials, I set the configuration port to 443 (because of the reverse proxy), but when I use 443 port or 80 I get the error message shown previously.
If I set the port to the standard 5672 I get a timeout, obviously, because my nginx is not listening to that port directly; it is actually listening to 80 and 443 port and redirecting it to the rabbit docker container’s internal 5672 exposed port.
This is my RabbitMQ credential configuration:
2- Tried from a different server behind an AWS load balancer, (NOT nginx), with docker as well and I’m having the same issue as with nginx (exact same error message).
3-Tried using a cloudamqp.com pre configured account, and the workflow worked correctly. I have also created a new server from scratch with RabbitMQ (not dockerized, and not behind any type of reverse proxy), and worked well with the standard port 5672.
The issue seems to be with the reverse proxy somehow. What I am missing here?
Thanks for your help.
