Hi there, I’ve set up two Rabbitmq server, one in my local and one in cloud. When I use rabbitmq node (sender) it throws me this error: There was a problem executing the workflow: "Socket closed abruptly during opening handshake"
Do you know what the problem is ?
Sorry, sadly not crazy much experience with RabbitMQ. So the best thing would be to Google this issue. Here for example a discussion about the same issue: https://github.com/squaremo/amqp.node/issues/101#issuecomment-123457011
No need for being sorry. Thanks for your help
You are welcome. Hope it was helpful and you can figure out the problem!
