RagMetrics n8n Node — Evaluate AI outputs for hallucination and accuracy directly inside your workflow
Hey n8n community :waving_hand:
Just launched a native RagMetrics node for n8n.
If you’re running LLM outputs through your workflows — RAG pipelines, AI agents, document processing — you can now score every response for hallucination, accuracy, grounding, and compliance directly inside n8n.
How it works 3 nodes and you’re live: Trigger → Edit Fields → RagMetrics Evaluation
The node returns structured JSON with:
  • Criteria scored (Accuracy, Hallucination, Grounding etc)
  • Score 1–5 with detailed reasoning
  • Token usage for cost tracking
Use the score to route low-quality outputs to human review, trigger alerts, or log everything to your RagMetrics dashboard automatically.
Get started :page_facing_up: Node docs: https://ragmetrics.ai/resources/n8n-node :high_voltage: Starter workflow: https://ragmetrics.ai/resources/n8n-simple-workflow
Questions or want help: :e_mail: olivier@ragmetrics.ai :mobile_phone: +1 917 767 4075
