I really enjoy using n8n with Raindrop. I previously was having issues where my integrations would stop working every so often. Turns out, there was an issue with the refresh token and how it was handled.
I’m once again experiencing issues where my flows are not working.
All flows that use Raindrop are broken. The flows are all similar – just deal with different Raindrop Collections. I’m not including all examples in this post.
I’ve tried to re-authenticate, but even that process seemed a bit suspect so I am hesitant to try again.
error
context:[empty object]
timestamp:1667248292844
node
parameters
resource:bookmark
operation:getAll
collectionId:27152399
returnAll:false
limit:10
name:Raindrop Get Bookmarks
type:n8n-nodes-base.raindrop
typeVersion:1
position
0:460
1:500
credentials
raindropOAuth2Api
httpCode:[null]
description:Body is destroyed
message:UNKNOWN ERROR - check the detailed error for more information
stack:NodeApiError: UNKNOWN ERROR - check the detailed error for more information\n at Object.raindropApiRequest (/usr/local/lib/node_modules/n8n/node_modules/n8n-nodes-base/dist/nodes/Raindrop/GenericFunctions.js:30:15)\n at processTicksAndRejections (node:internal/process/task_queues:96:5)\n at async Object.execute (/usr/local/lib/node_modules/n8n/node_modules/n8n-nodes-base/dist/nodes/Raindrop/Raindrop.node.js:125:40)\n at async Workflow.runNode (/usr/local/lib/node_modules/n8n/node_modules/n8n-workflow/dist/src/Workflow.js:658:28)\n at async /usr/local/lib/node_modules/n8n/node_modules/n8n-core/dist/src/WorkflowExecute.js:562:53
lastNodeExecuted:Raindrop Get Bookmarks
mode:trigger
Please share the workflow
(Select the nodes and use the keyboard shortcuts CMD+C/CTRL+C and CMD+V/CTRL+V to copy and paste the workflow respectively)
- n8n version: Version 0.200.1
- Database you’re using: default for Docker container
- Running n8n with the execution process: Running via Docker
- Running n8n: via Docker
<Repasting from another thread, following a request from @Jon>
I am once again having trouble with my flows that use Raindrop.
I had been having errors here and there, but wasn’t concerned. Starting 10/27, it’s been failure after failure after failure on multiple flows that use Raindrop.
I’ve tried re-authenticating with Raindrop.
last node that was executed was Raindrop Get Bookmarks.
My version of n8n has been upgraded.
n8n Version 0.200.1
</end repaste>
