@EmeraldHerald here the link of invoices i am working with you can access
https://drive.google.com/drive/folders/1St1-zMwWl3gaEKPLgPxlx2fbxpDE6ss8
Hi @Arudhra - that link only returns one data file:
Can you please try adding this node after your HTTP Request node:
And seeing if that works for you? If not, can you share where in your workflow youâre getting stuck with sample data? As @MutedJam mentioned above, your workflow runs just fine with what youâve provided
Youâre not receiving the data from the HTTP Request node as binary data, so thereâs no file for the Read PDF node to operate on - you can change that like this, in the HTTP Request node under Options â Response:
When using your file and fixing this up, however, I am getting the error âInvalid PDF Structureâ, but this would be an issue with the file youâre sending to n8n. Iâm not having any issues when using a sample PDF such as the one here: https://unec.edu.az/application/uploads/2014/12/pdf-sample.pdf
That being said, itâs entirely possible it matches the structure Mindee expects - you can try to take out that Read PDF node to test that. Thereâs otherwise an issue with the file itself
@EmeraldHerald Did you try placing the file in the folder and reading the file from the folder, if so can you send me the workflow
Hey @Arudhra,
You shouldnât need the Read PDF node before the Mindee node, Can you share what the output of the HTTP Request node looks like and also the input and output of the Mindee node?
The output there is pdf
so for the binary data property in the next node should be pdf
instead of data
but if you are sending the PDF to Mindee there is no need to read the PDF in n8n just send it direct.
i am getting the below error
404 - {âapi_requestâ:{âerrorâ:{âcodeâ:âNotFoundâ,âdetailsâ:âSubscriptionProduct not foundâ,âmessageâ:âResource not foundâ},âresourcesâ:[],âstatusâ:âfailureâ,âstatus_codeâ:404,âurlâ:âhttps://api.mindee.net/v1/products/mindee/expense_receipts/v4/predictâ}} - 404 - {âapi_requestâ:{âerrorâ:{âcodeâ:âNotFoundâ,âdetailsâ:âSubscriptionProduct not foundâ,âmessageâ:âResource not foundâ},âresourcesâ:[],âstatusâ:âfailureâ,âstatus_codeâ:404,âurlâ:âhttps://api.mindee.net/v1/products/mindee/expense_receipts/v4/predictâ}}
Details
Time
10/20/2023, 7:21:43 PM
Stack
NodeApiError: The resource you are requesting could not be found
at Object.mindeeApiRequest (/usr/local/lib/node_modules/n8n/node_modules/n8n-nodes-base/dist/nodes/Mindee/GenericFunctions.js:39:15)
at processTicksAndRejections (node:internal/process/task_queues:95:5)
at Object.execute (/usr/local/lib/node_modules/n8n/node_modules/n8n-nodes-base/dist/nodes/Mindee/Mindee.node.js:221:44)
at Workflow.runNode (/usr/local/lib/node_modules/n8n/node_modules/n8n-workflow/dist/Workflow.js:658:19)
at /usr/local/lib/node_modules/n8n/node_modules/n8n-core/dist/WorkflowExecute.js:631:53
Mindee
Execute node
Parameters
Credential for Mindee Receipt API
Resource
Operation
Binary Property
Fixed
Expression
RAW Data
Fixed
Expression
I wish this node wouldâŚ
Problem in node âMindeeâ
Hey @Arudhra,
That error is saying that data
in the Binary Property doesnât exist. If you look at the input binary item it is actually called pdf
so if you change the Binary property to pdf
it should work.
On the second one if you go to the nodes settings for the Mindee node change the API Version from 1 to 4 and that should work.
@Jon i have changed the API version
But still getting the same error above
can you guide me where to change the binary property
I am getting I valid file type
00 - {âapi_requestâ:{âerrorâ:{âcodeâ:âBadRequestâ,âdetailsâ:{âdocumentâ:[âInvalid file type: text/htmlâ]},âmessageâ:âInvalid fields in formâ},âresourcesâ:[],âstatusâ:âfailureâ,âstatus_codeâ:400,âurlâ:âhttps://api.mindee.net/v1/products/mindee/invoices/v4/predictâ}} - 400 - {âapi_requestâ:{âerrorâ:{âcodeâ:âBadRequestâ,âdetailsâ:{âdocumentâ:[âInvalid file type: text/htmlâ]},âmessageâ:âInvalid fields in formâ},âresourcesâ:[],âstatusâ:âfailureâ,âstatus_codeâ:400,âurlâ:âhttps://api.mindee.net/v1/products/mindee/invoices/v4/predictâ}}
Ah yeah that file is an html file not a PDF file. Can you try downloading a PDF file to see if you get the same issue.
If i download the PDF file i am getting HTML only
Can you show me what the output looks like with a PDF file?
Can you show me what the output looks like in n8n when you download one of the PDF files?
