Receive attachment and process with ollama vision model
New here. After hours of research, digging through questions, templates, and tests, I’m kind of stumped for what I think should be basic.
In a self hosted n8n installation, I’m receiving an attachment in a webhook, to which I want to use a vision model with ollama to describe the contents of the attachments.
I can’t seem to pass the data to the model. I’ve tried turning the file into base64 and passing it in the user prompt, but it doesn’t detect the image.
Does anyone have a basic workflow example of llama3.2-vision receiving a prompt and image?
here’s the output on the last step:
  • **n8n version:lastest local
  • **Running n8n via (Docker, npm, n8n cloud, desktop app):docker
  • **Operating system:wsl (windows sub linux with docker containers)
This flow will receive an image from a telegram bot, performs an anlyses and sends the analyses to telegram.
It uses moondream but you can select ollama-vision in de node yourself. Obviously I removed my own ids for telegram.
I primarely use it to take images of something with my mobile and then have the image analyses done by the AI and have the result send back to me in telegram
if this was helpful then hit the ‘solution’ button :slight_smile:
