Reddit doing things… Ahah!
Yes, the auth worked fine.
Thank you for your time trying to fix the Reddit issue!
Does it still work for you? Because if not, I seem to have missed the window of opportunity…
Hey @Zottelchen,
Just checked and it appears to be from here still. My small VPS seems to be ok as well.
It could be worth trying the desktop app to see if that is working for you.
Still working here for now
So, my desktop instance would work, but my Docker instance still doesn’t…
That sounds like what we were seeing before, we didn’t get to the bottom of it and it just started working so I suspect this is going to be another case of waiting for Reddit to sort out their stuff which is a shame.
