Reddit Lead Radar: finding "looking for a tool" posts with RSS + Gemini (and what I learned about Reddit's rate limits)
Hi everyone :waving_hand:
I built a workflow that watches a few subreddits for people who need what you sell, has Gemini score each post 0–100, saves the good ones to Google Sheets and sends the best to Telegram with a reply idea. It never posts on Reddit; you reply by hand.
Flow Schedule (2h) → Config (Set) → Build feed URLs (Code) → HTTP Request (Reddit RSS) → Parse & pre-filter (Code) → Google Sheets (read logged IDs) → Remove already-seen (Code) → Loop Over Items → HTTP Request (Gemini) → Parse score (Code) → Wait → Sheets append + Telegram alert
A few things I learned building it that might save you time
Reddit’s
.json
endpoints return 403 without OAuth, but RSS still works.
subreddits/new/.rss?limit=100
returns an Atom feed with the newest 100 posts. No API key needed.
Unauthenticated RSS is limited to about 1 request per minute. After a single request the response headers showed
x-ratelimit-remaining: 0.0
with a 60-second reset. I use the HTTP Request node’s batching (batch size 1, interval 65000 ms), so each subreddit adds about a minute to a run.
Don’t combine subreddits into one feed (
r/a+b+c
). It returns the newest 100 posts overall, so a busy sub crowds out quiet ones. In one sample, r/SideProject took 93 of the 100 slots. One feed per sub, then round-robin when picking which posts go to the AI, fixed it.
Pre-filter before the LLM. A plain keyword filter (“looking for”, “any tool”, “struggling with”…) plus an exclude list for self-promotion (“i built”, “looking for feedback”, “beta testers”) cut 400 fetched posts down to about 10 worth scoring.
Don’t trust a small model with conditional instructions. I asked Gemini Flash-Lite to “mention the product only if the score is 70+”, and it mentioned it anyway on a 65-score post. Now it returns
reply_advice
and
disclosure
as separate fields, and a Code node adds the disclosure only when
lead_score >= 70
Dedupe in two layers. Saved leads are skipped via the Sheet (post_id column). Low-scoring posts are remembered with
$getWorkflowStaticData(‘global’)
so they aren’t re-scored. Note that static data only persists for active (production) runs, not manual test runs.
Results from a day of testing on r/Upwork, r/freelance, r/n8n and r/Freelancers: 36 new posts scored, 6 saved as real leads, 0 scoring failures.
If anyone wants the complete workflow with the setup guide, I’ve packaged it here: Reddit Lead Radar: n8n workflow that finds people asking for what you sell
Happy to answer questions about the RSS limits or the scoring prompt.
