Hi there, I am trying to create a workflow where if the condition fails (“if current stage is valid” node), it should re-run the “Verify Stage” node.
On the first run, data from the “*Inject Data” node is getting passed to the “Verify Stage” node and works perfectly fine but on the second run, I am not able to pass data. I want to pass data from the *Inject Data” node with a slight modification to it. How can I do that?
One of the approaches you can take is as follows.
Use a Set node to set a variable. Connect this Set node with the False branch of the IF node. In your *Inject Data node, check if the value you’ve set in the Set node is available (or is not undefined). Based on that you can return the modified output that the Verify Stage can use.
You can also access all the data of the “*Inject Data” node in the Function-Node ("???") with $node["*Inject Data"].json, then you can do your transformation and output it again.
