Regex to match surrounding fields and extract text between (Modify node)
I have understood that you can match with regex specific data to extract surround info in the Modify node (with the mysterious grouping (?<! MATCH) with toString.
// Explanation on the grouping of match (?<! would be great. Any good references???
Anyway, an example:
Field “textblob” which contains “alotgarbage\nuser password:thesecretpassword\nmoregarbage”
I want to regex out “thesecretpassword” using regex (matching all potential characters,
between “\nuser password” and before the “\n” after the secret password.
The function needed to extract this to a new String value would be great.
:slight_smile:
  • n8n version: 1.25.1
  • Operating system: RHEL
@DkYSwe , here’s an example how that could be achived.
The solution assumes that the keyword “password:” is present as is. I did not use ?<! at all.
If you still interested to know what that is, here’s the document. It represents a search technique called “lookbehind” (there is also “lookahead”).
