Relation does not exist
i am getting this error : postgresql faild after runing this query: SELECT * FROM users, please i need help what wrong
some times it might just be you are using the wrong name , postgres is case sensitive , maybe you should check the name , i am very sure the query will be something like this below
SELECT FROM Users
please check
thank you sir, haha , it worked i thought it was a big error
no problem! i am glad it worked!
