Request for Maximum Free Trial Extension for Student/Educational Use
Dear n8n Support Team,
I hope you are doing well.
I am writing to kindly request an extension of my n8n free trial period. I am currently a student learning the n8n platform and using it for educational purposes to understand workflow automation, AI agents, integrations, and related features.
My registered account details are:
Registered Email: aksainnovations@gmail.com
Workspace URL: https://laasiakber.app.n8n.cloud/
Purpose: Student learning and educational experimentation
I would be extremely grateful if you could consider extending my free trial for the maximum period possible. The additional time would allow me to properly learn and practice the platform, build educational projects, test different workflows, and gain a deeper understanding of n8n.
I truly appreciate the support n8n provides to students and educational users. I would be very thankful if you could make an exception and grant me the longest trial extension available.
Thank you very much for your time, understanding, and support. I sincerely appreciate your consideration and look forward to continuing my learning journey with n8n.
Kind regards,
Akber Laasi
Hi @Akberlaasi, welcome!
Not sure if this is possible or not, only help@n8n.io can give you a valid answer, but I would recommend using a self-hosted n8n, which is basically free.
You will get all the useful information you need here: n8n Guide 2026 - Setup, AI, Hosting & Pricing | Anshul Namdev
