Required Property is missing / WHat can be possible solution
Create a workflow for getting invoice sent to email A. and if invoice will be sent to Email B. if not. end workflow. Trigger is when recieve email
Problem in node ‘Send a message‘
Required property is missing.
  • **n8n version:**Version 1.111.1
  • Database (default: SQLite): N/A
  • n8n EXECUTIONS_PROCESS setting (default: own, main): Own
  • Running n8n via (Docker, npm, n8n cloud, desktop app): N8n Cloud
@Aaron_Libago Your email sending node is missing the file attachment.
Replace your second “Code” node with an IF node set to check isInvoice is true. The IF node is better at passing files through than a Code node.
Does this answer your question?
sorry addtional question the code node is checking the pdf file also additional checking .. do i need to remove it ? and directly go to if condition ?
@Aaron_Libago Based on your workflow, you can simplify it by removing the Code node and using the IF node directly to filter PDFs, which is more efficient
kindly mark as the solution if I helped
