Hello fellas.
I was wondering, what the right way is to create batch records to baserow. It seems obvious that the Set node + Aggregate Item + Split In batches would be the key but I can’t get it to work properly.
How should I approach it?
I have used the Baserow node, however, workflow execution time crashes on record # 912, more less. And I need to update a couple of thousands records at a time. Thanks!
Please share the workflow
{“error”:“ERROR_REQUEST_BODY_VALIDATION”,“detail”:{“items”:[{“error”:“Ensure this field has no more than 200 elements.”,“code”:“max_length”}]}}",
- n8n version: 0.191.1
- Database you’re using (default: SQLite): yup
- Running n8n with the execution process [own(default), main]: own
- Running n8n via [Docker, npm, n8n.cloud, desktop app]: docker on vultr
