RSS SplitInBatches and Merge Problem
Hi, Im a new user and my English is bad, but Ill try to explain.
I want pass a “feedType” to Notion, so I try to use Merge
and fix “Code” node like this
return [
    "json": {
      "url": "http://www.199it.com/archives/category/entertain/mobile-games/feed",
      "type": "199it"
    "json": {
      "url": "http://www.gamelook.com.cn/feed",
      "type": "gamelook"
It can see “feedType” at Notion node
But it show “ERROR: texts is not iterable”
How to fix this?
This is my ERROR workflow
  • n8n version: 0.224.4
  • Operating system: Ubuntu
It`s me again, the problem is solved.
I found I should set the line after the Notion node and back to SplitInBatches node.
It seems mean where the line end and back to SplitInBatches, is a loop.
Just like this.
