kristus
November 26, 2024, 1:09pm
1
Hi, i switched off docker running n8n as the npm -g package. Everything works fine execpt that the “white label” shows n8n is running in DEV mode + i dont get the popups of update available like when it was in docker.
is there ENV var to turn it ti “prod” and get the updates available?
my systemd service has
Environment="NODE_ENV=production"
Environment="WEBHOOK_URL=url"
Environment="VUE_APP_URL_BASE_API=url"
Environment="GENERIC_TIMEZONE=Europe/Berlin"
Environment="NODE_FUNCTION_ALLOW_EXTERNAL=*"
Environment="NODE_FUNCTION_ALLOW_BUILTIN=*"
Thank you
Debug info
core
n8nVersion: 1.68.0
platform: npm
nodeJsVersion: 22.0.0
database: sqlite
executionMode: regular
concurrency: -1
license: enterprise (production)
consumerId: 2bb6fb9a-e036-4857-b9fe-26efe698ef68
storage
success: all
error: all
progress: false
manual: true
binaryMode: memory
pruning
enabled: true
maxAge: 336 hours
maxCount: 10000 executions
n8n
2
n8n version:
Database (default: SQLite):
Operating system:
BramKn
November 26, 2024, 1:14pm
3
Hi @kristus
May I ask why you moved away from Docker? This is the recommended way of hosting n8n.
Updates are always available as long as you update it. It will not automatically update normally.
Not sure how to remove the DEV though,
kristus
November 26, 2024, 6:35pm
4
two main reasons.
On that machine i used docker just for n8n. Figured why to waste resources running docker if i can run it directly.
It made it much more easier to use custom cli_tools (via Execute command node) in workflows from that machine. Beofer that it was rather unpleasent
I can see in the Dockerfile they use
npm install -g --omit=dev n8n@${N8N_VERSION} --ignore-scripts
but wasnt sucessful with that.,
I am running it as npm package on my homelab for some time and few months back the logo was still wihout DEV for npm global package, it is quite recently added so it was a conscious decision from someone on the dev team
netroy
November 26, 2024, 7:01pm
5
can you please try setting N8N_RELEASE_TYPE=stable
in the env variables.
kristus
November 26, 2024, 7:50pm
6
netroy:
Hi, yes thats the one. Thank you.
It fixed both the logo + the updateAvailable modal
system
Closed
December 3, 2024, 7:50pm
7
