Running Node Persists After Completion
When executing my workflow, the HTTP node completes but doesn’t move onto the next node (image 1). Interestingly, the input/output viewer bugs during this for maybe 10-20 seconds before returning to normal (image 2).
[WebSocketClient] Connection lost, code=1006 (browser console)
The output was a binary data file, as expected. As explained above the issue is in regard to that not being passed to the next node.
  • n8n version: 1.113.3
  • Running n8n via (Docker, npm, n8n cloud, desktop app): Docker, Apache
  • Operating system: Ubuntu
Looks like your request return nothing.
Did you make sure the request return the binary as expected?
Sounds like the HTTP node is finishing but not handing off data properly. A couple of things you can try:
  • Check the binary data handling → sometimes the next node expects JSON instead of binary. You may need to use a Move Binary Data node to convert before passing it along.
  • Since you’re on Docker + Apache, also check reverse proxy/WebSocket settings (timeouts or buffering can cause the [WebSocketClient] Connection lost, code=1006 issue).
  • Make sure you’re on the latest n8n version, sometimes these bugs are fixed in newer builds.
If you want, feel free to share a simplified workflow or reach out to me at [email protected] and I can help debug further.
Thanks for your reply. I can’t do the former as I need to upload the file in the HTTP request, which wouldn’t work with the JSON extract. In regard to the latter, here is my env file/Apache config if that helps:
Apache
<VirtualHost *:443>
  ServerName n8n.<mydomain>.com
  SSLEngine on
  SSLCertificateFile    /etc/letsencrypt/live/n8n.<mydomain>.com/fullchain.pem
  SSLCertificateKeyFile /etc/letsencrypt/live/n8n.<mydomain>.com/privkey.pem
  ProxyPreserveHost On
  ProxyRequests Off
  RequestHeader set X-Forwarded-Proto "https"
  RewriteEngine On
  RewriteCond %{HTTP:Upgrade} =websocket [NC]
  RewriteRule /(.*)           ws://127.0.0.1:5678/$1 [P,L]
  ProxyPass / http://127.0.0.1:5678/ keepalive=On retry=0
  ProxyPassReverse / http://127.0.0.1:5678/
  ProxyTimeout 3600
  TimeOut 3600
  LimitRequestBody 0
  ErrorLog  ${APACHE_LOG_DIR}/n8n_error.log
  CustomLog ${APACHE_LOG_DIR}/n8n_access.log combined
</VirtualHost>
.env
DOMAIN_NAME=<mydomain>.com
SUBDOMAIN=n8n
GENERIC_TIMEZONE=America/New_York
SSL_EMAIL=<name>@<mydomain>.com
NODE_FUNCTION_ALLOW_BUILTIN=*
NODE_FUNCTION_ALLOW_EXTERNAL=*
N8N_PUSH_BACKEND=websocket
N8N_HOST=n8n.<mydomain>.com
N8N_PROTOCOL=https
N8N_EDITOR_BASE_URL=https://n8n.<mydomain>.com
WEBHOOK_URL=https://n8n.<mydomain>.com/
N8N_PAYLOAD_SIZE_MAX=1073741824
N8N_DEFAULT_BINARY_DATA_MODE=filesystem
I attempted to add:
Which would in theory increase the limit more than enough for my 12mb upload and 170mb output. Unfortunately, this did not work. To clarify your last point, I am on the latest version.
