Running same workflow for 100s of people
I have this need - I have a workflow that works with my personal Google calendar. I want to run it ob behalf of my employees - each of them has their own Google account. I can ask them to connect their account once but then I just want to run it for each of them passing the Google connection.
So my solution was - create new workflow that calls the sub-workflow as many times as we have the connections either in loop or just a step using Sub-worflow node.
Any thoughts how can this be done?
using cloud n8n
Hi @Dima_Semensky
There is probably a better way of doing this.
What are you actually doing with the workflow?
You can probably do it with just 1 account with extra permissions.
I want to develop a single workflow - like checking user calendar and deploy it for 100s of people using their own credentials
