Hi guys.
I’m generating a CSV file and sending it to S3.
Due to compliancy my credentials only allow me to PUT an object and this can be done successfully using the aws-cli in the command line. My credentials doesnt allow me to GET object or bucket.
After spending some hours due to 403 error in this node I came to the source code and realized that in this line a GET in the bucket (or object) is done to retrieve the region. (n8n/S3.node.ts at master · n8n-io/n8n · GitHub)
Note that the region is informed in the node configuration - and doing it like it is being done brings me some points:
- cant the region inputed in the node configuration be used here?
- in order to PUT an object I need extra permissions that in some cases (like mine) isn’t possible due to compliance reasons to have;
Any thoughts about this?
UPDATE 1:
- I had to add the permission “s3:GetBucketLocation” to the credentials in order to use the node. I believe this permission should not be required if the location used was from the node configuration.
