Could it be possible to have a Salesmate.io (https://salesmate.io/) integration ?
Can you please explain what functionality you would need exactly. That if it gets implemented we can be sure it can do what you need it to. Thanks!
The API documentation can be found her
The integration could cover:
- contact/company search
- fetch contact/company details
- create contact/company
- update contact/company
- delete contact/company (?)
Additionally, the same action could be delivered for deals & activities
@Alain Hope you are fine. Just created this node. @jan will let you know when is released so that you can use it.
Regards
Ricardo
@RicardoE105 Great ! Thank you so much ! Kind regards, Alain
Did just get released with [email protected]
Am I missing something, seems there is no way to create a Contact. Only a Company… maybe the API changed in 2 years? What would be the correct way to have the integration updated to support Contacts? Otherwise we might have to use HTTP request node.
