Same result after 2 times test in cours 1
I’m facing an issue with the quiz in Course 2 on Nathan (Extraction Data from EDW). My workflow runs correctly and I get the expected results, but my score remains unchanged after submitting the test. All my selections seem logical to me, so I’m not sure what’s wrong. I suspect the problem might be related to duplicated nodes in my workflow, but I’m not certain. Has anyone experienced the same issue or found a solution? Any help would be greatly appreciated.
Hi @Hyacinthe, welcome to the community of n8n.
I had same issues that made me doubt if I was understanding correctly the questions. Would you be so nice to paste your code and I help you to find the issue?
I really appreciate @DrPonka it about the test question I have answered all the questions and I still have 77%
I guess there are some tricky questions that can make it a bit difficult to understand exactly what is requested.
Maybe this video from @sandy4v can help you to understand where you´re making the mistake. He explains in an easy to follow way what is requested!
