Save Highlight Data / Execution Data: Add visual indicator to execution history lists
The idea is:
For the “Save Highlight Data” feature, where you can use the Execution Data node to dynamically add key/value metadata to executions from within the workflow, you can currently filter on that data in the executions list view.
I would like there to be some sort of visual indicator in the executions list view (global, and the workflow execution view) that shows a given execution has highlight data present - I suppose, to highlight that execution :wink: Currently filtering works on the global and workflow executions list, but it could be a pleasant/lower friction experience to have a visual indicator without any filter present for quickly identifying executions of interest (assuming you don’t care about viewing executions WITHOUT any highlight data)
My use case:
Easily viewing executions where I’ve saved highlight data, without having to author a filter, or load/view/close executions without highlight data, which wastes time.
It will make use of the highlight data more efficient and obvious.
N/A
Other feature requests exist that share the concept of this, with tagging and such, but this is an improvement on an already present (recently added) feature, vs a net-new feature.
No - it’s better for everyone if I stay out of front-end code :smiley:
