:: I had a 5 second schedule trigger node repeating and it bloated my SQL so bad I had zero memory, no room to move. I was able to secure the one workflow I had managed to stack together over a number of hours through workflow/SSH errors. But all my credentials and history are all gone.
And there was no warning at all. I woke up from a nap and even my VPS logins were suffering (no room to store IP-pins). If this happened like…2 months into development, I’d be crushed. Like, I might as well have a virus eat all my work.
Is there a way to prevent and/or restore major issues like this? I hate having to nuke everything.
Thanks for any suggestions.
:: N/A
:: I can’t at the moment, everything was erased.
- n8n version:
- Database (default: SQLite):
- Operating system:
