Hello,
I need to get notified when rows are updated in Seatable.
For this, I configured the n8n Seatable trigger connection (Cloud-Hosted) and provided the API Token of the Base.
When I click Execute Workflow, I Automatically receive null values and poll time interval is not respected. Also, there is no difference if Simplify is checked or not.
It is not clear to me how this trigger is working. Normally, you’d have to set up a webhook in Seatable Base → Advanced Settings and then insert the same webhook in your trigger node/module, etc.
I can only see a Base Token required in n8n and I do not understand the output I receive from this trigger. Seems to not be related to any change or row addition in Seatable. The response with null values is just sent automatically when I click Execute Workflow.
Is it possible to subscribe to row update notifications? This would be the use case for my project and I can only see “Row Created” option for event subscription.
Thank you in advance!
- n8n version: 0.208.1
- Running n8n: Self-Hosted
