Hi n8n Academy team,
I’m working through the Foundations course and Section 1 (“Academy Registration”) isn’t marking as complete, even after some time and signing out/back in.
Assessment ID: 6e796a3f8b60b5cfa536f74c241e31bd
What happened:
I built the registration workflow exactly per the instructions (Manual Trigger → HTTP Request, Header Auth with X-API-Key, correct assessment ID, workflow_name and tag copied exactly as specified). Executing it returns 200 OK, but with an empty response body — not the documented JSON response with a confirmation code, congratulations message, and timestamp.
I noticed the page for this exercise says “Your results will be graded externally,” so I suspect the grading process is looking for that confirmation payload specifically, which my request never received.
For context: a separate, unrelated section (Interface Navigation / Platform Orientation) had a similar “not marked complete” issue that resolved itself after some time and a sign-out/sign-in — so I know progress sync can be delayed in general. But this one hasn’t resolved even after the same wait, which is why I think it’s specific to the missing confirmation response rather than a general sync delay.
Troubleshooting already tried:
- Verified the credential’s header name (X-API-Key) and value are correct (confirmed via the 200 OK)
- Confirmed the assessment ID matches exactly what’s shown on my profile
- Signed out and back in — no change
Could you check whether my registration was actually recorded on your end for this assessment ID, and if not, let me know how to trigger a proper request that returns the full confirmation response?
