Selection box often not working
Sometimes I can’t drag the selection box. It’s not appearing.
To fix it I have to open/close a random node.
Very annoying bug.
Hi @artildo, I’m sorry for the trouble.
We’ve got an item Open node on single click (and fix node selection bug) on our internal bug tracker, though I do not have an ETA yet. But hopefully this will eventually be solved :slight_smile:
@MutedJam Found workaround.
Click on any node and then click on canvas (or again on any node). This brings the box back. Maybe this will help to fix the issue.
