I have a window server I installed n8n using npm on it and and started nomally i configure a domain using iis reverse proxy i trying to listen that particular n8n port running i also use .env file writing some confugration related when i trying to access the URL n8n connected but not showing me the login page shows a popup in bottom-right, Error connecting to n8n
Could not connect to server. Refresh to try again
and in console there are errors like–
1=> sentry.js:1
Failed to load resource: net::ERR_NAME_NOT_RESOLVED
2=> ResponseError: Can’t connect to n8n.
at request
3=> Failed to load resource: net::ERR_NAME_NOT_RESOLVED
n8n version: ==> 1.88.0
Database (default: SQLite): default
n8n EXECUTIONS_PROCESS setting (default: own, main): own
Running n8n via (Docker, npm, n8n cloud, desktop app): npm
Hii, Thanks for replying yes i locally its working fine I test it with the command curl localhost:PORT its returning me proper html response and in browser n8n login console.
I made a reverse proxy to my port made an inbound rule on my domain to redirect my selected port on which n8n is running i guess the problem is in my config file.
