Self hosted AI Starter Kit - No usable system locales were found
  • I am not sure what the issue is.
  • I entered the commands that are mentioned on the github page for Nvidia GPU users.
  • After the commands are entered and everything is downloaded and it attempts to create the containers, it mentions that there are no usable system locales.
  • Commands:
    git clone https://github.com/n8n-io/self-hosted-ai-starter-kit.git
    cd self-hosted-ai-starter-kit
    docker compose --profile gpu-nvidia up
✔ Container qdrant                                      Created                                                 126.2s
 ✔ Container ollama                                      Created                                                 126.2s
 ✔ Container ollama-pull-llama                           Created                                                   3.0s
 ✔ Container n8n-import                                  Created                                                   2.7s
 ✔ Container n8n                                         Created                                                   2.7s
Attaching to n8n, n8n-import, ollama, ollama-pull-llama, qdrant, postgres-1
postgres-1         | The files belonging to this database system will be owned by user "postgres".
postgres-1         | This user must also own the server process.
postgres-1         |
postgres-1         | The database cluster will be initialized with locale "en_US.utf8".
qdrant             |            _                 _
postgres-1         | The default database encoding has accordingly been set to "UTF8".
qdrant             |   __ _  __| |_ __ __ _ _ __ | |_
postgres-1         | The default text search configuration will be set to "english".
qdrant             |  / _` |/ _` | '__/ _` | '_ \| __|
postgres-1         |
qdrant             | | (_| | (_| | | | (_| | | | | |_
postgres-1         | Data page checksums are disabled.
qdrant             |  \__, |\__,_|_|  \__,_|_| |_|\__|
postgres-1         |
qdrant             |     |_|
postgres-1         | fixing permissions on existing directory /var/lib/postgresql/data ... ok
qdrant             |
postgres-1         | creating subdirectories ... ok
qdrant             | Version: 1.11.1, build: 8a46eb12
postgres-1         | selecting dynamic shared memory implementation ... posix
qdrant             | Access web UI at http://localhost:6333/dashboard
postgres-1         | selecting default max_connections ... 100
qdrant             |
postgres-1         | selecting default shared_buffers ... 128MB
qdrant             | 2024-08-28T04:04:36.453595Z  INFO storage::content_manager::consensus::persistent: Initializing new raft state at ./storage/raft_state.json
postgres-1         | selecting default time zone ... UTC
postgres-1         | creating configuration files ... ok
postgres-1         | running bootstrap script ... ok
postgres-1         | sh: locale: not found
postgres-1         | 2024-08-28 04:04:37.271 UTC [35] WARNING:  no usable system locales were found
qdrant             | 2024-08-28T04:04:38.136826Z  INFO qdrant: Distributed mode disabled
qdrant             | 2024-08-28T04:04:38.136895Z  INFO qdrant: Telemetry reporting enabled, id: d2837def-866e-43e6-90fe-509aae3ec2da
qdrant             | 2024-08-28T04:04:38.144866Z  INFO qdrant::actix: TLS disabled for REST API
qdrant             | 2024-08-28T04:04:38.145036Z  INFO qdrant::actix: Qdrant HTTP listening on 6333
qdrant             | 2024-08-28T04:04:38.145068Z  INFO actix_server::builder: Starting 11 workers
qdrant             | 2024-08-28T04:04:38.145081Z  INFO actix_server::server: Actix runtime found; starting in Actix runtime
qdrant             | 2024-08-28T04:04:38.153721Z  INFO qdrant::tonic: Qdrant gRPC listening on 6334
postgres-1         | performing post-bootstrap initialization ... ok
qdrant             | 2024-08-28T04:04:38.153764Z  INFO qdrant::tonic: TLS disabled for gRPC API
Gracefully stopping... (press Ctrl+C again to force)
dependency failed to start: container self-hosted-ai-starter-kit-postgres-1 is unhealthy
PS C:\Users\justi\self-hosted-ai-starter-kit> nable Watch
Hi @Spectrem12
Can you share which docker engine you are using and what your config are for it?
