Trying to deploy n8n with queue mode in render. But the worker deployment fails for some reason.
But all the others are working fine. Main n8n, Postgres, Redis everything good.
What is the error message?
Deployment fails with the following error message.
==> Deploying...
==> There was a problem starting your server: "worker": executable file not found in $PATH
==> Cause of failure could not be determined
Here is the render.yaml
file
services:
- type: web
env: docker
region: oregon
plan: standard
branch: main
numInstances: 1
healthCheckPath: /
envVars:
- key: DB_TYPE
value: postgresdb
- key: DB_POSTGRESDB_HOST
fromDatabase:
property: host
- key: DB_POSTGRESDB_DATABASE
fromDatabase:
property: database
- key: DB_POSTGRESDB_PORT
fromDatabase:
property: port
- key: DB_POSTGRESDB_USER
fromDatabase:
property: user
- key: DB_POSTGRESDB_PASSWORD
fromDatabase:
property: password
- key: QUEUE_REDISDB_HOST
fromService:
type: redis
property: host
- key: QUEUE_REDISDB_PORT
fromService:
type: redis
property: port
- key: EXECUTIONS_MODE
value: queue # Enable queue mode
- key: QUEUE_BULL_REDIS_HOST
fromService:
type: redis
property: host
- key: QUEUE_BULL_REDIS_PORT
fromService:
type: redis
property: port
disk:
mountPath: /home/node/.n8n
sizeGB: 10
- type: web
env: docker
region: oregon
plan: standard
branch: main
numInstances: 1
healthCheckPath: /
dockerCommand: "worker"
envVars:
- key: DB_TYPE
value: postgresdb
fromDatabase:
property: host
fromDatabase:
property: database
fromDatabase:
property: port
fromDatabase:
property: user
fromDatabase:
property: password
fromService:
type: redis
property: host
fromService:
type: redis
property: port
fromService:
type: redis
property: host
fromService:
type: redis
property: port
disk:
sizeGB: 10
- type: redis
ipAllowList:
- source: 0.0.0.0/0
description: everywhere
region: oregon
plan: starter
databases:
- name: n8nDB
plan: starter
I think the dockerCommand
is wrong.
and ofc, I have .env
file properly with all the variables.
Any ideas?
- n8n version: latest
- Database (default: SQLite): postgres
- n8n EXECUTIONS_PROCESS setting (default: own, main): queue
- Running n8n via (Docker, npm, n8n cloud, desktop app): docker? using it on render
- Operating system: not sure.
