Is there a node or some other way to control exactly what is send to a model? For example there should also send nor “HUMAN:” Keyword.
Yes. You can use this node:
If my reply answers your question, please remember to mark it as a solution.
Hello Solomon, thank you for your answer.
Afaik, this only works with the models from OpenAI, but for the wide range I have to use the “AI Agent” or “Basic LLM Chain”.
I see. In those nodes you have some extra options you can add.
Just open the node and click the button on the bottom and you will see things like:
- system message
- sampling temperature
With those options you can have full control over what you are sending to the model.
Is that what you are looking for?
no, but I now can give an example:
from langchain_core.prompts import ChatPromptTemplate, PromptTemplate
chat_prompt_template = ChatPromptTemplate.from_template("teststr")
prompt_template = PromptTemplate.from_template("teststr")
print(chat_prompt_template.format())
print(prompt_template.format())
Output:
prompt_test.py
Human: teststr
teststr
Process finished with exit code 0
The ChatPromptTemplate adds the “Human” part automatically and also n8n nodes does. I know that most models need the “Human:” keyword word running correct, but my question is, how I can get the full control on what is send to the model in n8n.
