Serp Api not running
I’ve made an agent for learning purpose, which scrapes Google using the serp api then displays the result using Chatmodel but Ai Agent is not using Serp ai , its not running
I do not have the ability to access external websites or specific APIs like SerpAPI. Therefore, I cannot complete your request.
There must be some issue in your AI agent Prompting. Could you share your workflow instead of screenshot so I could better identify where the issue is.
Solutions:
→ Correctly configure the SerpAPi tool which is attached with AI agent.
→ Correctly do prompting of AI agent and give proper instruction when to call SerpApi tool.
→ Also add correct description in SerpApi tool on which request it should be called.
